2004 nissan sentra single 12 cerwin vega stroker updated
this is my 2004 nissan sentra 1.8s sedan. i am college student going to the unversity of northwestern ohio. i am going for auto/diesel associate degree and alternative fuels degree. i also have a job with school so it leaves little to work on the car. between work and school i have 40 hours a week of work and another 20 hours a week of school. so i am working on my car audio set up slowly.recently i replaced the passanger side sway bar link and struts all the way around. i just replaced the air fuel ratio sensor on the car yesterday. but on to my set up
here is my audio setup
Alternator: stock (soon to upgrade to bigger high output)
head unit: kenwood excelon kdc-x396
Front speakers: hifonics zues 6.5 components
rear speakers: jbl coxail 6.5 speakers
amp for mids and highs: ct sounds 60.4
amp for sub: hifonics brutus brz1700.1d
subwoofer: cerwin vega stroker 122
sky high car audio zero guage power and ground wire.
big three with sky high wire as well
ResizedImage_1378669942268_zps9b1b1aa7.j
ResizedImage_1378669931665_zpsba64f004.j
ResizedImage_1378669916599_zps4cff5e1d.j
the black paint that is under the driver and passanger doors are aftermarket because i had to fix a rust hole below the driverside rear door. so i painted both sides to make it look natural.
now on to the big 3, i posted a question on this awhile back and put pictures up then but here they are agian:
here is the ground connection behind the battery
then that ground runs down to the transmission and another runs of the transmission so i up graded it too
the motor to chasis ground.
now on to the power side:
from the alternator to the fuse block
the wire runs in to the back of the fuse holder from underneath then the one up top leads to the cars power distribution fuses and relays on the hood.
the distribution center to the battery
now onto the interior of the car:
ResizedImage_1378670001925_zps0714454b.j
as you can see i changed some of the interior colors. i am working on turning all the plastic pieces in the car to black. with the exception of the pieces that are painted blue.
ResizedImage_1378669960498_zps35f0e331.j
ResizedImage_1378669950829_zpsbf8634ea.j
ResizedImage_1378669980758_zps37b74443.j
ResizedImage_1378669970626_zps4ecd3df7.j
ResizedImage_1378669993477_zps7cf6fe33.j
ResizedImage_1378670022593_zpsf48bc6a9.j
were the cubby whole blow the radio heater controls are i took a piece of plexiglass that is hot glued in place. I mounted my bass know abd volt meter there. the two switches 1 is for my amp for a shut off switch and the other is for the lights that are under my dash and the 1 behind the voltmeter and bass knob.
now on to the amp sub set up of my car:
hifonics brutus brz1200.1d
ResizedImage_1378670043653_zpsfd8470e6.j
yes those are 0 to 4 gauge reducers
ResizedImage_1378670014371_zps87e661f8.j
the box is tuned to 40 hz and is 2.3 cubic feet with a 4 inch areo port.
ResizedImage_1378670061450_zps1146e24d.j
that is all for now. i am going to post videos later
here is a video of the my system playing field party by the lacs and jj lawhorn
http://www.youtube.com/watch?v=OCCCti3feMg&feature=player_detailpage
then here is a vidoe of no hands in the playing in the car.
http://www.youtube.com/watch?v=PXhRgUpp7iI
then of the same song outside the car and some of the subwoofer.
http://www.youtube.com/watch?v=lQRl46Z_bBg
Let me know what you guys think. any advice would be great and open to comments
  • 5 months later...
  • Who's Online   0 Members, 0 Anonymous, 3374 Guests (See full list)
