need round port help
jmfrb1
Okay but I'm not doing a 6. I've decided on the dual 4. I don't have the space to properly run 6. it would literally be resting against my backseat. That was what I originally wanted and designed on Torres. so I'd rather run dual 4 with proper space then a single 6 with the port blocked.
Only one thing looks better than an 6" port. And that is my 8" port...lol
d742f0a5-4694-4a4f-bff7-8dd97483d6c1_zps
what are your the specs of your box and port. after A LOT of tweaking I managed to be able to do an 8" port. what's your port per foot? And what subs are you running? Obviously they're audioque but which ones?
I pretty much ripped my trunk apart. Made some card board boxes n cleared/relocated everything. Now I can do a dual 6" or single 8. So which has more port area? Or are they about the same?
Subs are in my sig. HDC3's. box is 37" w x 17.5" h x 19" d. Outside dimensions. subs are strapped on two ddm2b's. Box is tuned to 36hz. Just metered on a termlab and hit a 147.8 at 43hz. which was my loudest hz. It's tuned low. Im going to cut the port down alittle to raise the freq. will be tuning the box to 46hz. where she should peak at 53 to 54hz. which should push me to 150db. hopefully. Then everything is coming out after a midwest spl show this upcoming weekend. And I will be working on a over the winter build. I moved everything behind the b-pillar and the box is below the rear window line.
2001,2002,2003 USACI World Finalist. 3rd. place ss 301-600
2003 USACI World Record Holder SS 301-600
Out for 10yrs. Finally getting back in the game.
2-ddm2b's on 2 HDC3 12's. 147.8db for now on TL.
250amp alt. 4 deep cycle batts.
2 runs of 1 gauge.
98' dodge ram. Soon to be advance no wall class. Or ss class.
I believe the dual 6" will give you more port area.
2 runs of 1 gauge.
Alright cool man thank you. n sorry about the set up question I'm on my mobile right now.
damn you have your work cut out for you man. Good luck on your road to 150+!
thank you.
2 runs of 1 gauge.
thanks.
2 runs of 1 gauge.
  • Who's Online   0 Members, 0 Anonymous, 1426 Guests (See full list)
