02 grand am help with air horn
i have a cheap air horn with a relay. positive and negative on compressor, any wire diagram for my cars horn trigger? ( + or - ) ??
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
  • 3 months later...
The factory horn wire is black (-) under the steering column but your best bet is to wire the relay as follows:
Pin 86 connect to factory horn (+) wire
Pin 85 connect to factory horn (-) wire
Pin 87 connect to compressor positive
Pin 30 connect to battery (+)
Just ground compressor and you'll be good to go pin 85 and 86 can be switched so you won't have to get horn polarity wires determined and doing it this way keeps you from having to run long lengths of wire or go digging under your steering column
Also if you disconnect your factory horn push the button and hear a clicking there is already a horn relay as most gm cars have which you could then just hook those two wires on factory horn directly to compressor with no extra relay needed
"Custom isn't bought its created"
