Got a question about glueing the surround
jdawg90
So I'm in the process of doing a recone and have already glued the spider in place. I want to use amazing goop on the surround... the package says to apply to each surface and wait 2 minutes before letting them touch. That's not really practical with the surround glued. Would I be okay laying a bead and clamping right away? And how long do I need to let the glue cure before hooking them up?
I recently used amazing goop and I reglued a surround to a cone that had ripped off the cone. I lifted the surround and clamped it immediately and it worked just fine. I let my sub dry for about 2 days before hooking it up but I am sure you could play it way before then.
why cant you use the same glue that you used to glue the spider?
i dont understand why you want to glue the surround when you said you already glued it...wat?
When I made the thread I had only glued the spider. I'm using the glue sundown told me to use: 5 min epoxy on spider and goop on the surround. I actually just glued it with the goop, I was able to fold the surround back with one hand and put glue over most of the lip.
  • Who's Online   0 Members, 0 Anonymous, 6054 Guests (See full list)
