Mitsufan1 Posted November 4, 2013 Report Posted November 4, 2013 I need some help finding the specs for some subs. I am going to be buying 2 10" MTX 7500 from my friends dad. They are are in a sealed box. I searched online for the specs but I keep finding mixed results. I was wondering if someone could help me find the specs and also give me some advice for an amp. I am going to be putting this in my 95 Mitsubishi Eclipse GS. This is my first car so it is my first install for a sound system. Any help would be appreciated. Thank you.
truthsayer Posted November 4, 2013 Report Posted November 4, 2013 Size 10 -inch Impedance 4 ohms Cone Material Mica-filled polypropylene Surround Material Nitrile Butadiene Rubber Ideal Sealed Box Volume (cubic feet) 0.75 Ideal Ported Box Volume (cubic feet) 1.25 Port diameter (inches) 12 Port length (inches) 22 Free-Air No Dual Voice Coil Yes Sensitivity 90.79 dB at 2.83 watts 88.44 dB at 1 watt Frequency Response 47 - 150 Hz RMS Power Range (Watts) 200-400 Peak Power Handling (Watts) 400 Top Mount Depth (inches) 6 11/16 Bottom Mount Depth (inches) 7 5/16 Cutout Diameter or Length (inches) 9 1/2 Vas (liters) 14.3 Fs (Hz) 45.97 Qts 0.79 Xmax (millimeters) 66.05 Parts Warranty 1 Year Labor Warranty 1 year If your looking for a good reliable amp class D, and dont want tp spemd much. Go to amazon and get a pioneer GM-D series, you can pick one up for about $125. I just wouldn't waste to much on a high dollar amp for those subs. By the way i got your sub specs directly from Crutchfield, so they should be accurate. truthsayer
Mitsufan1 Posted November 4, 2013 Author Report Posted November 4, 2013 Thank you very much for the specs. So for the amp I should be looking at something like this? http://www.amazon.com/Pioneer-GM-D8601-Class-Amplifier-Remote/dp/B00A02QLVA/ref=sr_1_1?ie=UTF8&qid=1383546645&sr=8-1&keywords=pioneer+GM-D+series
truthsayer Posted November 4, 2013 Report Posted November 4, 2013 Thank you very much for the specs. So for the amp I should be looking at something like this? http://www.amazon.com/Pioneer-GM-D8601-Class-Amplifier-Remote/dp/B00A02QLVA/ref=sr_1_1?ie=UTF8&qid=1383546645&sr=8-1&keywords=pioneer+GM-D+series That will be a great match for your subs. The amp also has a bass remote. These amps are very efficient, if you read the reviews you probably already know that. And it will put out the rated power. I run 2 pioneer gm-d's and i love them. truthsayer
Mitsufan1 Posted November 4, 2013 Author Report Posted November 4, 2013 Awesome. Thank you for your time and help. Much appreciated.
truthsayer Posted November 4, 2013 Report Posted November 4, 2013 Awesome. Thank you for your time and help. Much appreciated. No problem, and welcome to the forum. truthsayer
Mitsufan1 Posted November 5, 2013 Author Report Posted November 5, 2013 Will this amp work for a box that has 2 chambers? The subwoofers are connected to different terminals. The box kinda looks like this http://i.ebayimg.com/00/s/NDEzWDY4MA==/z/3rwAAOxyiBpSLk0P/$(KGrHqJ,!lQFIetijf,KBSLk0Pm24g~~60_35.JPG?set_id=880000500F but the terminals are in the back of the box.
Mitsufan1 Posted November 5, 2013 Author Report Posted November 5, 2013 Am I going to need a 2 channel amp for a box like that?
