2011 dodge challenger RT air ride
Here is my 2011 Dodge Challenger on Universal Air Suspension Kit. ( lx kits)
Using 1/2 valves DOE , 3/8 air line, dual compressor setup viair 444 4 gallon aluminum tank
9 button switch box. using oem shocks and struts for now. will be getting mopar Bilstein Pursuit shocks and struts. also I have my python 2 way alarm/remote starter remote controls the air ride using the aux output channels.
Before the air ride install
Now the install
all the parts from the kit is laid out prepping for install
Toxic Orange 2011 HDP Dodge Challenger RT
Universial Air Suspension
22" Kartier Forged wheels
Flowmaster American Thunder Cat-back
soon to come audio build
- Ground Zero Hydrogen 30x subs
- Ground Zero Plutonium 3 way components
- singer wiring and accessories
SQ Build Logs
Facebook https://www.facebook.com/pages/Hinnant-Design/102693809895087
Time to prep the air tank for paint, satin black. My powder coat guy was backed up for the month, so I had to do this myself since I had some down time
between car audio builds.
SQ Build Logs
Next I had to assemble all 8 valves and fittings for the lines, tank and compressors.
Now the trunk area, I like all my installs to look stealth so I installed everything in the spare tire area.
The spare tire was removed
SQ Build Logs
screw rivets were drilled and pressed in place for the air tank
SQ Build Logs
More screw rivets were put in place for the fuse holder, 80amp relay and grounds
SQ Build Logs
610368cb-fca9-4083-be7a-5da641bcb509_zps
Next building the compressors and valve lines board
SQ Build Logs
running wires for the switch box and running air lines.
drilled holes for the air lines
SQ Build Logs
wired up all the valve lines
SQ Build Logs
SQ Build Logs
After the install is complete, this is what it looks like
10da243f-3538-4c4d-9a9a-6727d67e2238_zps
SQ Build Logs
