96 4Runner with 2 Fi Q 18s (lots of pics)
man, you aren't joking around when it comes to bracing a box lol looks sweet! when you gonna glass in the fender wells?
Several factors had me go this route for bracing.
I didn't want the bracing to be the weak point that would make me have to rebuild the box. Since it is 52" wide, I could only get two cuts per whole sheet of MDF, so it got expensive quick.
I wanted the bracing to be round, and didn't think wood would be suffient for the calling of this specific box.
Solid rod allowed me to capture extreme strength, but a low profile (and thus minimal "stolen"internal volume)
Materials cost $42 as well (with extra remaining). Since I can weld,, it made it a no brainer.
As for the fiberglass, I am away from my shop for about a month. I live 100 miles away
I am in pharmacy school, so my focus will be on finals.
I'll be sure to post updates as soon as I have them
Yes I have a lot of stereo weight. I build for Smiles Per Gallon not Miles Per Gallon LOLZ
My build - 1996 4Runner with 2 18s - 149+ in a sealed box (with radiators)
0a4ee87c-28c8-4bf8-9dfe-5a06b9dea2dc_zps
3e3eb9dd-70f8-4424-ad11-ccebcd929ac4_zps
  • 4 weeks later...
  • 1 month later...
Well I kinda put this off for a while.
After exams last semester, all my time went into finishing this up and working.
Pretty much every day this year has been an average of 10 degrees or less, so it's been slow.
I "finished" the build the first week of January, just in time for CES.
Pulled it into the shop with exactly 210k miles, so that's two memorable moments in one haha.
FFEAC80B-DCEE-4749-AD95-6A762FFF3C70_zps
I have some pictures from Vegas and CES as well if you would like, but for now I'll keep it at my 4Runner
Two cool things from CES was talking to Ken Block for a while, and sitting in Scott Buwalda's car after talking to him for a bit.
Anyway, took the advice of you guys and glassed the whole box.
There is at least one layer on all of the walls, and at least two layers at all the corner joints (over caulk). And something like six layers over the wheel wells.
79F8846C-8F22-4080-B5FC-4986B44373DB_zps
Sanded it 6 passes with 60 grit, then 4 with 120 and 2 with 200. Smooooooooth
A38DBEFD-6EDD-42A3-BF2F-AC8A83650D44_zps
E4824891-560B-4A0A-A6DC-BD684F4753D2_zps
5E1D1B5C-DB78-4989-9404-563A46292ED6_zps
Then I mounted up the beauty board, drilled some holes for my terminals, and cleaned it all out
Pretty little 8 gauge haha
219A6F49-016C-4F49-8DE9-84D9250176E1_zps
All finished up
A1556DBF-C0DB-47CC-8D3B-3855E88EEC91_zps
Just shows how NVX is rebranded kicker. The left two are kicker, the rest are NVX
4D3C7A50-3B3F-4935-A7BF-E26091B57A21_zps
All installed
7D550B2D-4FE2-4BFA-A7D6-0EF0B2E790B9_zps
Tied up so that it doesn't slap around
93DC4E13-9E35-4FD1-84C9-D0A1B560388F_zps
The other side
B59848E1-58B7-49AD-B5AE-0C8F73FF4A77_zps
D5877463-EE43-4854-ABCB-CAF95B8D3A0A_zps
Now for power
57A1B0EE-FE27-473B-883F-81EFB58F7A75_zps
For the 400.4 (temporary)
E4B8557B-B4C4-41DA-A24F-55AD9C5C7A04_zps
"Final" setup. The RF amp is crooked, but this was a temp thing just so that I could finish by CES, and I will be going to a larger amp to try and keep up with the low end power. I will make welded steel supports after SBN most likely, with an amp for fronts and rears and a 360.3 in the center.
CA21174C-D331-423A-B22F-0B77E4E0C154_zps
It looks like a crazy mess, but actually most cuts are equal length cuts.
I am usually very neat wit my wiring, as I hope you can see from other sections of the build, but I have special wants for this part.
I drive around 100 miles every time I drive the vehicle, and am at just shy of full tilt for the entire time.
Every power run is fused, and there are two runs between every battery, which guarantees I will always have proper amperage flow, even if one fuse blows.
Very much overkill, but it is what I felt was proper for this vehicle.
  • Who's Online   1 Member, 0 Anonymous, 1543 Guests (See full list)
