GueroZ28 Posted December 8, 2013 Report Posted December 8, 2013 Have 2 db drive single 4 ohm voice coil 600watt peak k1-12s4 and i have a vented box.. but it says a vented box with 1.65cu ft would be best.. how do i know how much cu ft my box is and does it really matter?
shanesauce Posted December 8, 2013 Report Posted December 8, 2013 Get the outer dimensions of the box and subtract your material thickness from each dimension. Mutiply the length, width and height together and divide by 1728. Can you describe your goal? And yes box volume is that important. - 2012 Mustang 3.7 Manual - Audio under construction
GueroZ28 Posted December 8, 2013 Author Report Posted December 8, 2013 Get the outer dimensions of the box and subtract your material thickness from each dimension. Mutiply the length, width and height together and divide by 1728. Can you describe your goal? And yes box volume is that important. What do u mean goal?? In cm or inches?
