TravisMcBryde Posted January 5, 2014 Author Report Posted January 5, 2014 How much volume do you show the port displacing? I'm tired and don't want to do the math? Also where did you come up with 45" in port length? What did you use to determine that? 64.75 inches square. And My buddy DylanBunch told me to keep adding port length until I got the tune I wanted [sharedmedia=garage:vehicles:2615]
Jessica Posted January 5, 2014 Report Posted January 5, 2014 I get 2.0 cuff port displacement. Give or take Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
TravisMcBryde Posted January 5, 2014 Author Report Posted January 5, 2014 I get 2.0 cuff port displacement. Give or take If the displacement is in cubic ft its 1.79cuft [sharedmedia=garage:vehicles:2615]
CleanSierra Posted January 5, 2014 Report Posted January 5, 2014 Do you only listen to Decaf and chopped and screwed music? SQ brand subs typically like a higher tune than 30 Hz. You're port length it's pretty close for the desired running you want(I assumed the box would be 3.5 cubes after sub displacement and the port which is about 1.75 cubes with my rough off the top of my head math). Im not the one you want to try to troll. Just a fyi for you.
Jessica Posted January 5, 2014 Report Posted January 5, 2014 I get 2.0 cuff port displacement. Give or take If the displacement is in cubic ft its 1.79cuft Did you add the port wall to you displacement or just figure the internal dimensions of the port Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
TravisMcBryde Posted January 5, 2014 Author Report Posted January 5, 2014 Do you only listen to Decaf and chopped and screwed music? SQ brand subs typically like a higher tune than 30 Hz. You're port length it's pretty close for the desired running you want(I assumed the box would be 3.5 cubes after sub displacement and the port which is about 1.75 cubes with my rough off the top of my head math). Only decaf yes and math is correct but port is 1.79 [sharedmedia=garage:vehicles:2615]
CleanSierra Posted January 5, 2014 Report Posted January 5, 2014 So take a piece of paper. Draw an aerial view of your enclosure and label your measurements. I'm talking about everything, even the .75" for the thickness of the sides of the enclosure. Draw your port. Now, make a line down the middle of the port. That line needs to be centered. It would be 1.75" from either wall of the port. Draw that line straight to the back of the box and stop once you've reached 1.75". Make a 90° turn and take that line straight down, parallel, with the back of the box. When you go to figure out your length for the pieces of wood, all you have to do is use that 1.75" and subtract from your length. The 45" needs to be obtained by measuring down the center line though. Im not the one you want to try to troll. Just a fyi for you.
Jessica Posted January 5, 2014 Report Posted January 5, 2014 Show me your math for your port displacement please Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
CleanSierra Posted January 5, 2014 Report Posted January 5, 2014 I get 2.0 cuff port displacement. Give or takeIf the displacement is in cubic ft its 1.79cuftDid you add the port wall to you displacement or just figure the internal dimensions of the port I added the port wall, but I did all the math in my head. So it could definitely have an error Im not the one you want to try to troll. Just a fyi for you.
CleanSierra Posted January 5, 2014 Report Posted January 5, 2014 Strange duck, you're right on it. I busted out the pencil and paper since I wasn't firing the comp up. I get 2.01 cubes displaced by the port Im not the one you want to try to troll. Just a fyi for you.
