rockislife04 Posted January 8, 2014 Report Posted January 8, 2014 hey, new here and wasnt sure if this is the right place to get a hand. I have been following meade for a bit now and have been interested in calibrating my amp to my sub but cant afford something like his porducts. Anyone know of a tutorial of how to do the crossover and distortion with a multi meter?
Aj11 Posted January 9, 2014 Report Posted January 9, 2014 figure out what volt you need to set it to. ex, 1000w at 1ohm is 31.6 volts. turn your volume 3/4 of the way up all eq on the deck flat. put the red and black wiresfrom the mm into your speaker poutlets on your amp(subs not hooked up!) turn the meter to volts play a 40hz sine wave and Adjust gain until you see the desired volt reading. pm me for Any questions. there's a Lil more than that but there's a 1,000 videos on line how to do it. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Jessica Posted January 9, 2014 Report Posted January 9, 2014 That doesn't really work because the amp doesn't see any load with a dmm. So V×?=?. And that is just VA, not even sure if power factor is an issue with no load on the amp. Anyway. It will get you close I guess. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
