ok when i first started my install i had 2 12'' sony xplod P5s at 4 ohms and a mtx rt4240. i originally ran them 2 channel. i recently got a kicker comp which is 8 ohm. so i wired my box with the 2 sonys to 8 ohms then i bridged the amp to one channel and put both the sonys(wired to 8 ohms) and and the 8 ohm kicker on it which i figured would be a 4 ohm load. i heard you should never mix subs of differant impedance. but would it be fine in this setup?
should be ok i think
Head Unit: Pioneer DEH-P4050UB
Subs: 2 Pioneer Premier 12" ts-w3004spls
Sub box: 3.2ft3 tuned to 35hz
Sub Amp: SoundMagus DK 1800
Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts
Front Speakers: DLS MS5A components
2 gauge power & ground
