The equipment I used:
Pioneer DEH-P860mp
Focal 165 KRX3
K2 Power 3-way Component Kit (165KRX3 KRX3 Power Series)
Focal K2 Power 27 KX
11" 4-ohm subwoffer
Focal 5WS (2)
5" 4-ohm subwoffer
Alpine MRD-1000
Alpine MRV-540 (2)
Audio Technix 60 mil.
Monster cable
Sky High wire OFC
Welding Cable1/0
The first phase was planning. I tried many different angles, ideas on placement, specific goals and stealthy functionality.
I wanted to keep it a family car and still have a cargo space for things like the wives wheelchair, ice chest, groceries ect.
I take long drives often so I needed something that would be pretty loud and extremely dynamic. My taste in music is wide ranged.
Here are some preliminary pictures of the HHR, and key areas I was considering stealth
Sorry I did not take a lot of pictures.
One of the first things I did was acquire gear and prepare the doors. All four doors are deadened and sealed. I used heavy gauge galvanized sheet metal , some Liquid deadener and some Audio Technix deadener. I also used closed cell foam and placed it behind the woofers in each door. The process was the same for each door. I used the audio technix deadener to make seals.
Sorry. I didn’t do an order and didn’t snap enough pictures.
I was trying to stay away from too many modifacations but couldnt make the image work without cutting the a-pillar panel. the stage could be wider. but for this this is what I have come up with. I might change the angle later on. I did not get any pictures of my fabrication process. Sorry.
- - - Updated - - -
the pillars will be re wrapped. this was for testing. and I was kinda impatient about the dam thing taking so long
I added a second battery. stock alt does fine. these amps dont draw much current. 1/0 from bats to fuse block, 1/0 ground to distro block. 4awg to all the amps.
