fusing my amps?
Skax
Yes.
Does your amp have 4 inputs or 8 gauge inputs? If they are 4 awg inputs I would make it 4 awg.
No idea it's a old amp and can't find anything on it
Total Mobile Audio 440.4
Check if the 8 gauge fit snug or if there is room for more wire.
how can I check it's one of the ones where I had to clamp a terminal on it and slide it in and screw it down on the terminal ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Yes.
Ok. Then the 4 awg should fit with the right terminal.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
I can't really tell how big the fuses are but they look like 25s. you can get away with 8 gauge but if you can fit 4, then go with that. terminals look big enough for 4 gauge fork lugs
Personally I wouldn't go with an AGU style fuse block, I would find an ANL or Mini ANL fuse block and distribution block.
I would get this fuse block for under the hood and just choose the 250a fuse option
http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
and this for in the rear to distribute the power accordingly. Choose the 200a fuse and 50a for the other.
http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12
Why would he fuse above the wire rating???
He's upgrading to 1/0 awg. 250 amp is not above 300 amp(OFC) and it's the same as 250 amp(CCA).
Not to mention, 150 on 4 awg is at 20' not 4 foot like he is going to be running. The 200a fuse comes from the T1500 manual.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
im upgrading to 1/0 AWG CCA
so it can handle 250 amps if im reading correctly
so 250 amp fuse under hood
200 for the 1500bdcp
50 for the TMA 440.4?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
100% correct! That is exactly what you need.
ok so get the fosgate distribution block with a 200 and 50 amp fuse?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   1 Member, 0 Anonymous, 1175 Guests (See full list)
