fusing my amps?
Skax
partsexpress has wire lug fuseholders for 5.58. item number 263-630
what i think im ganna do is just what u said battery------>250------>250------>dblock------>amp
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
double post sorry
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
could you guys send me a link of a nice 250 amp fuse with a holder i could use and the dblock (with the fuses if i need them)
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Distribution block http://www.knukonceptz.com/productDetail.cfm?prodID=KNF-12
Choose 50a for both options as you have to buy a 200amp mini anl.
Under the hood fuse block http://www.knukonceptz.com/productDetail.cfm?prodID=FH-20
Choose the 250a option.
200 amp fuse http://www.amazon.com/XScorpion-Platinum-Blue-Mini-MIDI/dp/B0059BZEFG
I like the knukonceptz for under the hood because it is waterproof.
2010 Honda Civic LX / Deck: Kenwood DDX371 / Front Highs: Crescendo RTS-1 / Front Mids: Silver Flute 6.5's / 4 channel: DC Audio 90.4 / Sub: Fi 15in SP4v2 / Sub amp: Taramps HD 5000 / Power wire: Knukonceptz OFC 1/0 / Deadener: Audio Technix 60 mil / Batteries: XS Power D5100R / Rear bank: TBD / Alternator: Singer 240a hairpin
ok i went ahead and just did 2 fuses anyway never know when ill add a battery like Kranny said and just put it up in the garage order dblock with 2 50 amp fuses and the 200 amp fuse u showed me thanks guys :)
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
knus compression fittings are absolute garbage
In your opinion.
  • Who's Online   1 Member, 0 Anonymous, 1968 Guests (See full list)
