need help on wallin off my Grand Marquis!!
jpsaudio
Here's my equipment
270 mechman alt
3 kinetik hc2000's (plan on buying 3 more)
4 American bass XFL 15's with PSI recones so they are 1800rms 3600max dual 2ohm
i plan on buying 4 3krms amps
and a 97 mercury grand marquis
i have been talking with a few people and i have decided that i want a box with 2 subs on each side with the port in the middle tuned anywhere between 32-36hz. my problem is i have never built anything this big so i kinda dont know where to start. I will be using 1.5" MDF, i would like to hear advice on bracing i want this to be solid. i want to start building by the end of this month or beginning of next month...is re audio box builder a good starting point?
No re box builder is off. Download torres box calc its much better. And imo the first thing you should do is see how much airspace you have before buying stuff that may not work in it.
Edit: also will 270 amp alt be enough for 12k worth of amps?
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Yeah I'm not sure u have enough airspace or electrical for all that equipment. Think about walling a pair of high power 18's on 10 k or so. Unless I'm wrong which could be. List up ur max dimensions u have to work with.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
  • Who's Online   1 Member, 0 Anonymous, 1727 Guests (See full list)
