09 Chevy Impala Lt Build,Crescendo audio,Phoenix gold,SHCA
Where did you get your kick panels? What are you running in them?
That picture is not part of my build. The person you should ask is bcbrassard because it is his build picture.
So I got the box in it was a tight fit they are two separated box screwed together each box is 3 cubic feet tuned to 35hz
Here is the box before it got carpeted.
Amplifier all wired up.
Decided to put the kinetic 1400 in since I will be running every thing at 8ohms until I up grade my electric system.
Pioneer 5600
I started the big three right now I only have 1 negative run to the battery I will have to wait till they have more
sky high car audio 0 gauge ofc wire in stock to finish the big 3.
Kinetic battery next to a XS d3100.
The back passenger side drop a few inches when I put the XS D3100 battery in.
spring lifters.
No more sag.
Amp wiring all cleaned up.
The speaker got grounded to the door causing my 1100.4 to stay in protect. So I have to get the amplifier repaired.
So I put some electric tape on the terminals so it will not get grounded again.
