Treytesney Posted February 26, 2014 Report Posted February 26, 2014 I am new to smd forums so i hope im doing this right anyway i have a 2001 dodge ram 1500 with the infinity speaker package stock i was going to change them out once and after i got the door panel off and pulled the speaker out and i couldnt change them because of the amp that is located on the back of the speaker with a cluster off wires so i just sent the speakers back wich im glad i did because now i wont somthing else i was wondering if i could just cut the wires or what they all go to or how i need to do it now i wont a component system i wont to make shure i can do it before i find the ones i wont that will fit i dont like using sound shops doing ut yourself is part of the fun so please help thanks
MACnonsence6 Posted February 27, 2014 Report Posted February 27, 2014 go to google and type in what you wana know it should bring you to a schematic and tell u what it is. I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
SubaruBass Posted March 1, 2014 Report Posted March 1, 2014 i am about to do speakers in my wifes 99 Durango with the infinity system. i found an easy make it yourself amp bypass harness. this way you can avoid running new wire to the speakers and having to pull the HU.. less than ideal but a good quickie fix. if running a new amp i would run new good quality cable since the stock stuff is far less than ideal for quality and power DIY Harness: http://www.dakota-durango.com/forum/showthread.php?t=127337
