Vehicle: Kawasaki Teryx4 (2013)
Name: Kawasaki Teryx4 (2013)
Date Added: ÚTE_ADDED%
Owner: Rogue1970
Short Description: 2013 Kawasaki Teryx4. Purchased used with 25 miles. Installed LTI Long Travel suspension to double the suspension travel. Have a second set of rims/tires for the sand dunes. Chopped the roll cage 3"/3"/6". Crow 5 point harnesses installed, Modified stock seats for harnesses, Rigid Dome light, 2 4' SafeGlo LED whips, OEM Cargo box w/LED light, Bluesea 12 Circuit Box, 4 Eagle Eye LED reverse lights, 2 OEM LED headlights, 2 Baja Design Fuego 4" HID A-Pillar Lights.
View Vehicle
1989 Quadzilla 500 - Ported & Polished, JH#19 Pipe, Open Intake, blue printed
2003 F250 7.3L Crew - JVC KWAV60BT, Memphis X-O3, PG400.4, PG500.2, ID CTX6.5, JL Audio 10" Stealthbox
2013 Teryx4 - iPod Nano, MA6004 Marine Amp, Duner Tunes BT Volume control, SSV Works front pods, Sundown SD-8 4Ohm Dual
Hmm, I guess the garage adds a build log automatically.
Well here is a little more background on my build.
Of course when I'm offroad I want tunes, so I need something not easy to steal, durable, and inexpensive, but sounds decent!
Has to be a low power build as the stock charging system can't put out a ton of amps and there is only a few people looking to bump up the charging circuit right now on these. Stock output is about 24.2 Amps at ~12 volts and this has to support the vehicle and my other mods.
I did not want to have any kind of a head unit as this sees water (rain, washing, etc...), dirt, and sand. I decided on a 16GB iPod Nano that can be stored in the glove box as it connects to my system via Bluetooth.
6A3924F2-EAF0-44A9-A321-214BB7F21F2A_zps
Next was the volume control. I found the Duner Tunes BT volume control. Has play/pause volume up/down and track skip/previous in a simple knob design.
065E6B21-B74F-4099-813E-0B7276B997C3_zps
This has a remote turn on wire and RCA output that connects to my marine amp:
47076262-CD21-4EE3-A834-4812EA0A38A4_zps
I only have a cheap pair of RCA's hooked up right now. Again that was done to have tunes, but I still need to replace those with a better set I picked up.
Front stage goes to a set of SSV Works Pod 6.5" component marine speakers.
I had a trip planned and didn't have time to fab up the Pods myself.
Now I'm in the process of adding a Subwoofer for some thump. I bought the Sundown Audio SD2-8 Dual 4 Ohm sub since it is a shallow mount 8" designed for a small sealed box .25^3.
B664AEB5-BA01-4C3C-8FAF-C29CB02F5F67_zps
There is not a lot of mounting options in this offroard vehicle, so I mounted the amp on the right rear passenger back kick panel. The sub will be on the left rear passenger back kick panel. I've started the fiberglass box.
FF81B9B2-7D57-4894-8F06-93BF9DA23A79_zps
0C8DFA62-EA7B-41D9-9E00-086DAB46857B_zps
ABD4813B-FC8C-4B3F-9C5F-3F184F137767_zps
7794B89F-5836-4D8D-96EE-D10061DCA5CF_zps
Now I'm in the process of cutting speaker rings and some fleece to enclose the box.
Thats pretty badass man!
Thanks.
A little more work on the box.
C42D642A-C62C-49CA-8EBC-317F5BD14AB4_zps
F87F562C-6FFC-4DFD-97FB-5D9EB3E0860B_zps
F2C93E78-43E8-47E4-83FE-E0FA10DE7785_zps
AC223413-43CD-4C12-8DCB-70BD386A8504_zps
Waiting for the first layer of paint to dry before going with a final finish color. Flat black. Leaving the rough finish as this will get kicked since it is mounted at the rear passenger's feet.
