Jt Bradshaw Posted March 6, 2014 Report Posted March 6, 2014 Hey everyone. Im really confused about something and figured this is the best place to ask. The problem is that my 12 volt turn on wire coming from my car is only giving enough power to turn my head unit on part way. It will only show the theft deterrent light when the face plate is taken off. But if I hook the head units 12volt constant and turn on wire to the 12 volt constant of my car it works just fine. So what should I do?
jarrius Posted March 6, 2014 Report Posted March 6, 2014 How are you wiring it? Did you but a wiring harnes or are you hardwiring the deck directly in to the car? 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
funnyent Posted March 7, 2014 Report Posted March 7, 2014 That sounds strange. But if it works with the 12v constant hook up a relay from that to the switched power to turn on the system. A relay is like an on/off switch and the switched power will act as the trigger. Any automotive store or amazon sells them.
