Nick Chinn Posted March 23, 2014 Report Posted March 23, 2014 Hey guys. First time posting on the forum. My equipment and car are listed in the signature Ok so I want to add a second sub on my system (another Rockford Fosgate P3D4-10). I want to keep the cost low (Under $450 if possible since my part time job pay is shit). Right now, im running off the starting battery up front rated at 700 CCA with reserve at 120... my lights are dimming especially when the amp gets into the high frequency range (I do have an SMD volt meter and see the voltage go from 14.3V down to 12-11ish depending on the current demands). I don't get much voltage drop while driving but idling, yes and a lot too. When im driving I don't see it drop below 14.0-14.3V. To add a sub, I think I might need a second battery (current one im looking at is an XS Power D680), 200 amp isolator, and a XS Power AK 1000 wiring kit. Would adding a second battery help and could my alternator handle it? my alternator is rated 110 amps and reserve (not sure) is 44 amps??? Stock OEM cords from battery, starter, alt... etc... Would I solve it doing the big 3 as well to help out? The current starting battery I got in nov. 2012 so it would be just 1 yr and 4 months old. Im running my system bridged on the amp and the cap isn't doing crap... should I get rid of the cap if im adding a battery in the trunk? I would prefer not to upgrade my alternator if possible since I just don't have the finances to pay for a HO alt. (I get on average about $200 a week and im left with almost nothing in just a few days paying for gas, etc....) What are your suggestions? My car audio system: (truck: 2022 Toyota Tacoma TRD OR 4WD DCSB) DC Power engineering 270A alt Oddessy group 34R AGM battery Big 3 upgrade Aftermarket android radio Audio equipment: Stereo amp: Kenwood KAC-8406 sub amp: 1x Rockford Fosgate R2-1200X1 mono wired to 1Ohm 2 Rockford Fosgate P3D4-10 punch subs Enclosure: sub box shop . com vehicle specific for 3rd gen taco
Aj11 Posted March 23, 2014 Report Posted March 23, 2014 ditch the Cap (now I'll Wait..) ok now that's gone. a 110amp alt should be able to put a charge on a second battery. no need to run a iso if you don't thump your system while your car Is off. so doing your big 3 and adding a good amg battery upfront will help allot! oh what Amp are you.running? guessing right now your running at 2ohms? adding another dual 4 will drop you down to 1ohm. that will put more strain on your already tired electrical system. can your Amp run at 1ohm? if you have to go up to 4ohms then I'd wait until you can get a stronger Amp. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Nick Chinn Posted March 23, 2014 Author Report Posted March 23, 2014 Ok so I was planning to ditch the cap though from the start, really don't know why I spent money on it... should've never bought it in the first place.... I do run my system at times with the car off but that's hardly ever. but I think it would be good to have a iso etheir way... Il do the big 3 upgrade as well. Im fine with replacing the battery up front as I had trouble starting several times during the winter (in MN as we had 24 days of sub zero temps throughout the winter 2013-14). Im thinking it was because there was enough times when the amp was stealing power from the battery at idle.... Im running 8AWG from the main battery to the amp. I would prefer to keep the amp if i could since i got it free from a nice friend of mine.... But if i have to upgrade the amp, i will. This entire upgrade i want to do in mid to late April when the weather finally warms up enough to comfortably work outside.... I already ordered the box. http://www.amazon.com/gp/product/B003E4768S/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 Im running my amp in bridged settings right now which is 500W x 1 channel @ 4 ohms. I was told by crutchfield tech chat that i could run 2 of those on the amp if i wanted too.... My amp specs: KAC-7205 car amplifier Power Output 170W X 2 @ 4 Ohms 250W X 2 @ 2 Ohms 500W x 1 [bridged] @ 4 Ohms Amplifier General Features Class A/B 2-channel (stereo) car amplifier with MOSFET power supply LED power indicator Tuned Bass EQ (0-18 dB bass boost at 40 Hz) Speaker impedance: 2-8 ohms (4-8 ohms bridged) Bridgeable operation Speaker-level inputs with signal sensing for automatic turn-on Preamp RCA outputs Short circuit, DC offset, overload, and thermal protection circuitry Aluminum die cast heat sink Built-in cooling fan Gold-plated RCA level inputs Gold-plated screw terminals Variable low-pass filter (50-200 Hz, 24 dB/octave) CEA-2006 compliant amplifier Frequency response: 5-50,000 Hz Dimensions: 13-3/4"L x 2-5/16"H x 9-3/8"D UPC: 019048187451 Weight: 9 My car audio system: (truck: 2022 Toyota Tacoma TRD OR 4WD DCSB) DC Power engineering 270A alt Oddessy group 34R AGM battery Big 3 upgrade Aftermarket android radio Audio equipment: Stereo amp: Kenwood KAC-8406 sub amp: 1x Rockford Fosgate R2-1200X1 mono wired to 1Ohm 2 Rockford Fosgate P3D4-10 punch subs Enclosure: sub box shop . com vehicle specific for 3rd gen taco
Nick Chinn Posted March 28, 2014 Author Report Posted March 28, 2014 Ok im running 2 Rockford Fosgate P3D4-10" Punch series subs no problem. Il have to wait and see what happens. Suprisingly to me, i thought it would use more power but it isnt. My headlights arent dimming as much and i think i might not need as much stuff as i first thought. Still il take it to a car audio shop to and have them mesure the power output and see if i do need the stuff i bought or not. Edit: Im running it at 2 Ohms at 250 watts RMS with 500 watts max per channel as stated in the specs of the amp above. My car audio system: (truck: 2022 Toyota Tacoma TRD OR 4WD DCSB) DC Power engineering 270A alt Oddessy group 34R AGM battery Big 3 upgrade Aftermarket android radio Audio equipment: Stereo amp: Kenwood KAC-8406 sub amp: 1x Rockford Fosgate R2-1200X1 mono wired to 1Ohm 2 Rockford Fosgate P3D4-10 punch subs Enclosure: sub box shop . com vehicle specific for 3rd gen taco
youngbass98 Posted March 28, 2014 Report Posted March 28, 2014 Edit: nevermind 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
