Beyma Frequency and gain
I currently have a pair of Beyma 8PROMI connected to a Lanzar OPTI 4 channel 2000 watts. I'm trying to set the gains properly with a multimeter and a 1khz track. I know the max volume that I can use on my head unit. The 8 PROMI is rated at 200 watts RMS and 400 peak . To determine the max AC volts that I can use, should I calculate it with the 200 rms x 4 ohms or the 400 peak watts x 4ohms and then find the square root of course. The speakers are connected 1 to each channel stereo mode, I currently have the crossover on the amp set to hi pass and frequency at the max which is 750 hz I also have a Clarion EQS746, Im having a hard time getting it to sound right, I'm thinking I might need a 3 way crossover. The frequency range according to specs is 150hz-7000hz. I've always been told in the pass to avoid low frequency on Beymas. I was retired from the music game for like 5 years and need help.
  • Who's Online   1 Member, 0 Anonymous, 1566 Guests (See full list)
