Installing Hu In 04 Tahoe With Bose..
I would like to put in a new deck in the hoe along with some new front speakers. Is this going to be complicated?? I have the factory bose system with onstar that I never use. Do I need any special harnesses? I'm just trying to find out how much work I have ahead of me
if your not going to use the onstar you could just use a regular gm harness
and make shure to connect the remote wire(blue)
they make a adapter for that but it is really expensive you can get a regular gm harness tag remote turn on for factory amp then you will need to tag acc in the ignition harness thick brown wire because 03 and up dont have ign at radio they are data controlled
I was told that i might have to do some wiring under the front seat at the "fader switch" wtf is that??
no fader in that usualy the factory amp is in the factory center console if you ad a amp you would need to bypass it but if you only want to ad a deck you only need to mess with wires behind deck
