Hammer Knock Posted April 13, 2014 Report Posted April 13, 2014 Looking for the best shag upholstery for car interior, best i found so far is some red and black at hobby lobby. about 60x 60 for 13$? but looking for something with more shag then what i find there. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
Hammer Knock Posted April 14, 2014 Author Report Posted April 14, 2014 well also a shag with no shed. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
Hammer Knock Posted April 15, 2014 Author Report Posted April 15, 2014 yo, also need the best adhesive spray or best adhesive to use. if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
EP95 Posted April 15, 2014 Report Posted April 15, 2014 What's wrong with shag? Is this a serious question? Yeah, give me an explanation other it's "tacky" as to why its bad.
Hammer Knock Posted April 15, 2014 Author Report Posted April 15, 2014 nothing wrong with anything. self preference if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
thefourth Posted April 15, 2014 Report Posted April 15, 2014 http://bigzfabric.com/ That place should have exactly what you are looking for. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
Hammer Knock Posted April 15, 2014 Author Report Posted April 15, 2014 http://bigzfabric.com/ That place should have exactly what you are looking for. hows the shed report on the shags? if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
thefourth Posted April 15, 2014 Report Posted April 15, 2014 I myself only used a small bit of it. It does shed a little bit, nothing serious. That's expected. It won't shed in chunks or anything. Thanks alaskanzx5 I might just do thatI can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream. oh lawd.
Hammer Knock Posted April 15, 2014 Author Report Posted April 15, 2014 I myself only used a small bit of it. It does shed a little bit, nothing serious. That's expected. It won't shed in chunks or anything. right. well for the shed. im talking about with a light pull or what not. some dont at all if the car doesn't stall, you have enough voltage. DEH-6400BT BC3500D on 2 x 12" Lanzar Opti1233d QBOMB 4.5cu 1/0 awg, Lanzar AMPKIT0 Singer 275 + LCAKT50DBL
