Wiring and set up 4 channel amplifiers
evo90
This is only a rough guide i CANNOT tell you how to make it sound good to you . play with each setting to get a feel for the different frequencies.
OK so your front (tweeters ONLY) set between 8KHz and 12KHz
rear set between (MidBass ONLY) 500Hz to 6KHz
Sub (29Hz to 80Hz)
this is a very ROUGH guide.
Frequencies can sound very different due to, each persons personal prefrence , car , and equipment.
try to match frequencies to speakers output range EXAMPLE do not set your tweeters to accept 1.25 KHz if they are rated @4KHz to 22KHz
yes i skipped some frequencies i know ! i did this just for example .
No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement )
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
1 34s (Maybe time to change brand)
4 X 15" s
!/0 @ 2/0 OFC Wiring
:morepower1: :morepower1: :morepower1: :morepower1:
ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. :) once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus.
Sub (29Hz to 80Hz)
Yea its rought, but its better than nothing!
And i always confus then i see dis Khz or hz, or what ever, but thanks.
Which i need tune first head unit or amp?
Tune the head unit first then set amps (you may need to adjust both @ the same time to match output sounds) . REMEMBER to set your gain on you amp or amps all the way DOWN . adjust amps only after you are happy with the sound .
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
I just wondering, how properly set Gain, free distortion and no cliping for 4 channel amp.
I know one way how to set gain properly using smd- cc1 but what kind of frequensy (hz) i need to choice for 4 channel amp?
A SQ head unit
6 5.25
2 X 6x9s
7804
P400.4
4001D
4 X 15" s
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
