Dee-sa12 Posted May 5, 2014 Report Posted May 5, 2014 I am hooking up a second amp and I want to what size power wire should I use my amp to my subs is a 0 gauge and I haven't bought the second amp yet but I been looking and they need 4 gauge wire . What should I do
youngbass98 Posted May 5, 2014 Report Posted May 5, 2014 First off the power wire is the one that hooks to your battery and off the wire from your subs to your amp is speaker wire, biggest power wire you can fit 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Dee-sa12 Posted May 5, 2014 Author Report Posted May 5, 2014 Ok my amp that is for my subs is 0 gauge And the second amp, the biggest size is 4 gauge How do I make that work.
Guest Posted May 5, 2014 Report Posted May 5, 2014 what model is the sub amp. what model is the mids and highs amp. need information.
GSanders17 Posted May 5, 2014 Report Posted May 5, 2014 Use a distibution block. Run the 0 gauge to it, then run 0 gauge from it to bass amp, then a run of 4 gauge to the other amp.
Dee-sa12 Posted May 5, 2014 Author Report Posted May 5, 2014 And where would I find a block that does that.
GSanders17 Posted May 5, 2014 Report Posted May 5, 2014 Stinger SHD21. If you have a local dealer buy one from them if not I believe sonicelectronix has them.
youngbass98 Posted May 5, 2014 Report Posted May 5, 2014 Get a small second battery or I am pretty sure this would work too http://m.ebay.com/itm/390830733341?nav=SEARCH 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Dee-sa12 Posted May 5, 2014 Author Report Posted May 5, 2014 Ok it says 1 0 gauge in and 2 4 gauge how would I put a 0 gauge in to the outputs of the block if it's only 4 gauge
