load350z Posted May 23, 2014 Report Posted May 23, 2014 Hey, my subs sounded weaker then they use to(half the sound it use to be) automatically I thought one sub may have blown, so I took the subs out and checked the voice coils and the subs are fine. Now im assuming its the amp.. what do u guys think it could be? I had this amp since 2011 but only now had the chance to install it. From day one (2weeks ago) the amp gets really hot really fast even when there isnt a load on the amp. The amp was wired at 1ohm and never seen voltage below 13.4v. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted May 23, 2014 Author Report Posted May 23, 2014 I was thinking that too! Because I definitely don't want that amp to burn up.. today I'll try and relocate the ground I hope thats all it is 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted May 23, 2014 Author Report Posted May 23, 2014 Any suggestions where to ground it in the trunk of a 2002 altima? As of right now I have it grounded to the floor of the trunk where my spare tire use to be. I cut a 2x2inch square thru the factory deadening then sanded it to bare metal then bolted it. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Guest Posted May 23, 2014 Report Posted May 23, 2014 You should ground the amp to the (-) negative on your rear batteries
load350z Posted May 23, 2014 Author Report Posted May 23, 2014 I'll try post some pic once it gets light out so u can see how its wired 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
load350z Posted June 13, 2014 Author Report Posted June 13, 2014 .. found out my 40.1power supply side failed.. probably gonna need some fets and resistors replaced. Sucks. 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
