Guy Posted June 19, 2014 Report Posted June 19, 2014 Hey all, looking to get opinions on if i'm designing this box right. Going in a sedan, i can only fold down the middle of the back seat and use a small-ish hole into the cabin, and thought maybe having the port where it is would help get more sound through into the cabin? Also, I designed this box with Rockford's "High Output" size in mind.. will this still sound decent on music, or should I go smaller? (mostly trap/hip-hop/decaf) Sorry if the pictures are massive, noob at forum postingThanks guys Specs:Box Dimensions (external, 3/4" MDF):32"W x 15"H x 24"DPort Dimensions:13.5"H x 20"D, tuned to ~29/30Hz after disp.Volumes:Gross volume - 5.36ft³Port volume - 0.54ft³Driver disp. - 0.212ft³Net volume - ~4.6ft³ Holden Commodore Pioneer DEH2550UI Focal P165v30s Rockford Fosgate Power T1 12" @ 32Hz Audioline 40.2 Response Precision 1000.1 @600RMS, 2 Ohm
Steven144 Posted June 19, 2014 Report Posted June 19, 2014 Have never seen a port design like that before, wonder how it would sound?
load350z Posted June 20, 2014 Report Posted June 20, 2014 how much power u going to run? I currently have the same subs but after port and woofer displacement my box is right at 3.75cuft running off a rockford t1500bdcp. As I remember the subs requires 3.5cuft for a pair 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Cj Kumz Posted June 20, 2014 Report Posted June 20, 2014 Just make sure you not load straight into the port. And with that design you might cause cancellation too. Or you could try put the port on 1 side (3 common walls) so you have a little extra clearance from the port. Also your port area per cube is around 8 sq inches per cube, and the general rule for slots is 12-16 sq inches. I came with something like this. Just make sure you use 45s inside to help the air flow. Didn't have time to draw them Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
Guy Posted June 20, 2014 Author Report Posted June 20, 2014 how much power u going to run? I currently have the same subs but after port and woofer displacement my box is right at 3.75cuft running off a rockford t1500bdcp. As I remember the subs requires 3.5cuft for a pair I'll be running 600wRMS each to start until I can afford something like a 1500bdcp to replace my current two amps I think from the manual it was 3.5cuft for the smaller box and 4.5cuft for the bigger? I'm looking for more loud, but I certainly wouldn't mind losing some loud for more quality.. (Great thing about living in Australia - a 1500bdcp will cost well over $1k) Just make sure you not load straight into the port. And with that design you might cause cancellation too. Or you could try put the port on 1 side (3 common walls) so you have a little extra clearance from the port. Also your port area per cube is around 8 sq inches per cube, and the general rule for slots is 12-16 sq inches. Oh wow, that looks awesome. My only concern with a design like that is the physical size, I unfortnately can't go wider than 32" or taller than 15", but more depth is an option if needed... By "port on one side", do you mean a classic L-shape slot ported box? Looks like i'll be mucking around with more designs tomorrow Holden Commodore Pioneer DEH2550UI Focal P165v30s Rockford Fosgate Power T1 12" @ 32Hz Audioline 40.2 Response Precision 1000.1 @600RMS, 2 Ohm
load350z Posted June 20, 2014 Report Posted June 20, 2014 I ended up selling my t1500bdcp but I had them on my incriminator 40.1(3600watts) and they handled it if u dont get too crazy with the bass knob lol. Good luck with your build! 2002 Nissan Altima v6 3.5 Four Incriminator Audio Death Penalty 15s 5 Pairs DS18 Pro Audio X6.5BM 3 Pairs DS18 Super Tweeters Taramps TS2000x4 (Mids Amp) Incriminator Audio 6.4 (Tweeter Amp) Incriminator Audio 40.1 subs amp Rockford Fosgate 3sixty.3 3 shuriken batteries (BT-80 under the hood) (2 BT-120 in the trunk) with isolator Big 3 zero gauge. Excessive amperage H/O 225a Alpine head unit Lots of stinger deadener
Cj Kumz Posted June 20, 2014 Report Posted June 20, 2014 Yah ment the classic L-shaped bend. Let us know what you come up with man Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
Guy Posted June 20, 2014 Author Report Posted June 20, 2014 So I threw this together, 4.15cuft after displacement, so its a little smaller Tuned to ~29Hz. I used the RE calculator for this one so I kinda guessed the tuning after displacement, and i'll probably brace it too which would have some effect as well from what I know With this i'm basically looking for something that'll get loud for 2 T1s but still sound good (not going for massive SQ out of it, just want it to not be muddy/muffled), so feel free to tell me if my box is way too big, too small, whatever I've done a few for single subs that've come out decent but i've never tried anything of this size before Holden Commodore Pioneer DEH2550UI Focal P165v30s Rockford Fosgate Power T1 12" @ 32Hz Audioline 40.2 Response Precision 1000.1 @600RMS, 2 Ohm
Cj Kumz Posted June 21, 2014 Report Posted June 21, 2014 The box looks great hey. And 4 cubes will work fairly well with those subs.. Let us know how it goes Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
jacobS Posted June 21, 2014 Report Posted June 21, 2014 i built 2 boxes for a buddy with T1's. 2 cubes each tuned around 32hz sounded great, but i'd face the subs and port towards the hatch so it acts as a loading wall... just my 2 cents 1998 2 door tahoe Subs: 2 DC lvl4 18"s Mids/highs: nendo pwx 8" and 2 sets of 6.5" mezzo's Amps: hifonics 2500.1d & hifonics 1200.4 & RF 600.2 145.8 seald up in the kick.
