Logic Soundlab TX3000D
Mowgli
I have had this amp laying around for a while and can't remember how I acquired it. I used to run another of this brands amp when I first got into car audio some 12 years ago. Lasted a while but that doesn't mean it wasn't still shit. Figured I would open it up and snap some pics. The amp is very small, very heavy and claims to make a lot of power (lol). I will let the pictures do the talking. For those who can not see, it has three 35 amp fuses.
Stats:
Mono Block Power Amplifier
MAX Power (@ 1 OHM): 3000 Watts x 1 Channel
RMS Power (@ 1 OHM): 1500 Watts x 1 Channel
RMS Power (@ 2 OHM): 900 Watts x 1 Channel
RMS Power (@ 4 OHM): 500 Watts x 1 Channel
1 OHM Stable
Class D Design
PWM Controlled DC to DC Switching Power Supply
Built-in Variable Low Pass Filter: 50Hz - 150Hz
Built-in Variable Bass Boost Control: 0 ~ +18dB @ 45Hz
Built-in Variable Subsonic Filter: 15Hz ~ 40Hz
Remote Bass Control with Backlight
Internal Cooling Fan
Line In / Line Out Preamp RCA
Phase Shift Control: 0° ~ 180°
LED Power and Protection Indicators
Total Harmonic Distortion (THD): Less than 0.01% (4 OHM)
Signal to Noise Ratio: Greater than 98dB
Speaker Short and Thermal Protection Circuits
Dimensions: 7.32"(W) x 2.2"(H) x 12.72"(L)
PART_1407547549503_20140808_205419_zpsc6
PART_1407547543062_20140808_205519_zpsde
PART_1407547546480_20140808_205458_zps7d
PART_1407547547823_20140808_205438_zps70
PART_1407547544634_20140808_210333_zpsa1
PART_1407547541149_20140808_210347_zps14
PART_1407547539295_20140808_210412_zps82
Current: Two old school Orion HCCA 12's, No amp currently. Did run DAT Hellfire Prototype.
Old set up: Orion 2NT 15", Logic Soundlabs GSX32D,
  • Who's Online   0 Members, 0 Anonymous, 3760 Guests (See full list)
