? About Zapco's
CHINO11550
today i was f%$@#*& around with my Zapco's that i have running to my mids & highs & i noticed that when i moved one of the settings on the amp from Stereo to the L&R Sum Mono it was a lot louder. why is that & is that not good for my speakers or amp, i put the setting back to Stereo mode. can someone help with this ? thanks.
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
anybody ?
MLA module 15+volts
Team Bass Hz
From thew Zapco manual
"The second most common setting is the far right position, “L & R
Sum Mono”. In this position, the input stage will combine the left channel
and right channel information into a single mono channel, and feed that
information to both sides of the amplifier. You can then bridge the outputs
into a single bass channel or a single center channel. In both uses you will
have a single channel with the information from both channels of input.
NOTE: Left & Right Sum Mono is the position you will always use to drive
woofers only."
  • Who's Online   0 Members, 0 Anonymous, 5823 Guests (See full list)
