Help! First Build
zacka11en
Ok so this is my first box build (and system build) and am wondering if this looks right I want to do aero ports? The subs are two NVX VCW 15" with 2 voice coils 2 ohm
recommended box ported is 5 Cu., 2.5 Cu for each Sub. Some specs of the subs are - sensitivity 94.15 db, Top mount depth 7.57, Xmas 20mm, Qts 0.36, Qes 0.409, Re 3.20 ohms, Qms 2.910, and FS 27.9 Hz or 24 Hz kinda confused because this shows 27.9 Hz here -
and then on the other details page on NVX it shows 24 Hz and also shows the sensitivity different on this page!?
http://www.nvx.com/vcw152-15-1000w-rms-car-subwoofer-dual-2-ohm/
What i have is 15" high, 40 Width, and 27 depth with a 6in diameter aeroport 11" long
any suggestion?
  • Who's Online   0 Members, 0 Anonymous, 3202 Guests (See full list)
