95 Integra - Daily Project, B20b swap, AQ1200d, Rockford, Sundown
Set-up I currently have:
Exterior:
16" Motegi MR125
GSR Wing
_______________________
Engine:
B20b Swap (JDM Honda Orthia, CR-V)
4-2-1 Header (unkown brand)
2.5" Exhaust, cat replaced with flex pipe)
NRG MFL-301 Muffler
Spectra Ram Intake
Interior:
Blue LED Bulb Swap
GSR Black Cloth Front Seats
GSR Black Carpet
Eletrical:
Big 3 "SoundQuest SQK0 1/0 Gauge"
"SoundQuest SQK0 1/0 Gauge" from battery to "DB Link NANLFB02 0 AWG In/ (2) 4 AWG Out-2 Position ANL Power Distribution Fuse Block".
"Absolute ANL200-2" amp fuses in distribution block.
Headunit:
Pioneer FH-X700BT
Subs:
None (plan on a single 10" more below)
Sub Amp:
AQ1200d
I've finally got to the point where I decided I'm keeping the Integra for sure. I have a lot of unrecorded progress in this car already at this stage. When I first got it, it had a body kit which I was not too fond of, so I sold it back to the original owner of the car, who know has my Civic. The ecu was not chipped, so I got that take care of. The muffler on it was just a 4in tip, basically, so I had a new one installed. The shift linkage bushings were all blown out, and shifter was cheap ebay, that is all taken care of. Tires were pretty shot, so replaced rear tires and then rotate. The interior pieces were spray panted blue in several areas, I stripped the paint then repainted them black (the vents were resprayed and other parts completely replaced). Traded a buddy the Netami seats that needed some upholstery work for stock gsr clothes. There are some other issues and minor things that I've fixed mechanically, but has a lot and hard to remember.
As far as a sub set up I want to run my Rockford Fosgate He2 motor and basket with a Sundown SA-10 cone & surround, i will be buying a custom spider and voice coil for it soon! I will have more money invest in that after I plastidip the teg pearl white! I've got a ways to go but I will get it done!
Anyways I'll get on to the pics and will have a full details above! Hope you all enjoy!
As of 10/22/2014:
95 Acura Integra - 5-speed
Pioneer FH-X700BT
(2) Rockford Fosgate 12" P3
AQ1200d
Rockford Fosgate P1652-S 6.5" components
Rockford Fosgate P1572 5x7"
Rockford Fosgate R400.4
95 Integra Build Here
93 EJ2 Build Here
Good start! Love Integra. I have one too :D
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
