Vonroretz Posted November 24, 2014 Report Posted November 24, 2014 Hey I've had my soundqubed 3500 for a while now about 5 months been running real smooth no problems at all expect when I went to install another extra shuriken battery I had some issues . Now with the install completed and no problems at all go to set the EQ'S And all that fun stuff and no I got my awesome flat head Turing the gain and the LPF and now the amp will cut out when I mess with that whole circuit assembly .... Also the bass knob in there any one else have the same issue with this amp? Thanks
redwolf2 Posted November 24, 2014 Report Posted November 24, 2014 I'm not understanding clearly... It shuts off when you're playing with the adjustments? I would check your connections at your amp... Or even check your ground (as you could be leaning on it or something while you're messing with the adjustments) And what about the bass knob? Mine started acting funny and I just replaced the phone cable with another one (cheap enough to just try)
Vonroretz Posted November 24, 2014 Author Report Posted November 24, 2014 Grounds are good I mean the acutal equalizer itself inside the amp like the circuitry assembley seems to be loose or something
