Power_Man Posted December 2, 2014 Report Posted December 2, 2014 I want to build a new box for these subs. The first one i build was kind of rushed, as i was excited to get it all together. From what i have read on SMD, i want to change from a square port over to a aero port design. The box is in a Chevy Optra, or Suzuki Forenza hatch Back. So room is tight, but seemed to fit other box nice. Box has to be slanted to get most out of room. This is the space i have to work with. width: 36" Dept at bottom 22" Depth at top 11" Height 17" According to RF website this os what one sub requires. But i assume that changes if that box wont work for you and you have to change port up? Vb 2.00 cu. ft. 56.63 Liters F3 29.80 Hz Fb 36.00 Hz Height 16.50 in. 41.91 cm Width 22.25 in. 56.52 cm Depth 14.00 in. 35.56 cm Np 1 port Dp 4.00 in. diameter 10.16 cm diameter Lp 12.00 in. long 30.48 cm long Spk. Cutout 0.000 in. 0.000 cm Spk. Depth 8.88 in. 22.54 cm Vd 0.000 cu. ft. 0.000 Liters Vp 0.087 cu. ft. 2.471 Liters Thanks in advanced.
