Guest Posted April 4, 2008 Report Posted April 4, 2008 I used the RE Box Calculator and i ended up getting these dimensions...something tells me that if i cut all these parts out, they wouldn't fit together. Designed for 2 12's w/ .75" MDF, 4.6ft2 Bottom/Top Plate - 35" x 24" Left Plate - 23.25" x 13.5" <---- Right Plate - 22.5" x 13.5" <---- Back Plate - 35" x 13.5" Front Plate - 29.25" x 13.5" (shorter because of opening for port right?) Port Depth - 17.5" x 13.5" Port Width - 4" x 13.5" Why don't the left and right plates match each other when the box is rectangular.
NotoriouslyLoud Posted April 15, 2008 Report Posted April 15, 2008 right side is going to be short due to that being your port side. Same with the front plate, it as well will be smaller due to the port. I myself do not like the RE box calculator, i had some problems when using it for my last box. http://www.notoriouslyloudmafia.com http://www.teamwolfpackaudio.com
