best box plans for the Ground Zero GZNW 12 spl
Hi all.
What could be the optium box design for the gz? For spl?@35 hertz.
Its driver is the Massive Audio D8000 [email protected] ohm
110 amp dynamo 200amp cellpower battery
Factory recommended Box is 75liter Aeroport 16x26cm
Have this box now with flared port and round corners.
Unit of Measurement: Metric
Wood Thickness - 3.6 cm
Displacements - 0 Liter(s)
Frequency - 31.02 hz
Box Length - 52.5 cm
Box Width - 97 cm
Box Height - 32 cm
Port Length - 62 cm
Port Width - 7 cm
Port Height - 24.8 cm
Gross Volume(Feet) - 3.56 ft³
Gross Volume(Litres) - 100.81 L
Net Volume(Feet) - 2.62 ft³
Net Volume(Litres) - 74.19 L
Port Displacement(Feet) - 0.94 ft³
Port Displacement(Litres) - 26.62 L
Port Area - 26.91 in²
Port Area(Metric) - 173.6 cm²
Port Area Per Foot - 0.36in²
Port Area Per Litre - 2.34cm²
Sub parameters
ModelGZNW 12SPL
Handling4500 W SPL
PowerImpedance2 x 1 Ohm
SPL89,4 dBXmax50 mm
2"Fs30,2 HzQts0.39Vas38,6 L / 1.35 cu.ft.
Box recommendation vented75 Liter / 2.63 cu.ft. - Rohr / Tube 1 x Ø 16 cm / 6.3" - L= 27 cm / 10.6"Box recommendation sealed15 - 30 Liter / 0.53 - 1.06 cu.ft.
  • Who's Online   0 Members, 0 Anonymous, 2775 Guests (See full list)
