4 XFL 15s 2002 Mercury Mountaineer 3rd row
Tuned it nice equipment!
Thanks man
Gunnem, on 18 Feb 2015 - 03:38 AM, said:
3rd row made me think it was a normal box, not a wall
are you doing a cpillar wall??
Some type of wall not sure witch type yet
Need some wall advice guys want to start building it but I don't know what I should do and I don't want to build a forward facing wall if there is something louder. I'm all ears
Dont trust anything RE box builder says. It is a ballpark at best.
(Depth x height x width) x 1728 will get you gross volume. Use the internal dimensions. To get net volume you need to subtract sub displacement and port and bracing.
That being said, you will be cramped on space doing a c pillar, especially building inbetween the wheel wells.
You can build up and over wheel wheels and remove plastic trim to maximize space to get a lot more volume. I think a flat ported wall will be best. You dont have close to enough room for a 4th c pillar.
This is what I'm talking about. I could have moved the side walls out even further and made 45's to mate to roof.
It's always best to build as big as you can and shrink if need be when you are tight on space. And dont forget to allow room for equipment.
