Guest Posted April 18, 2015 Report Posted April 18, 2015 check out this vid on youtube for this problem I already have copper wire wrapped around my RCAs outputs and grounded it from my prvious amp...its still there now, and it does not seem to be helping... Did you used a multimeter on the ground points yet for the amp? No. For continuity? nope on impedence on the multimeter negative test lead to the negative post on the battery then a long jumper test lead from the positive on the multimeter to the grounding point where the amp is grounding at for this test Ok, I'll check the grounds for impedence...since I have rear batt, should I also front battery neg to rear battery neg? what are the numbers when you check it? about to go test them...should I disconnect the grounding wire and test it underneath or can I just test from on top of the lug? And i'll let you know.
Guest Posted April 18, 2015 Report Posted April 18, 2015 Tested front battery to ground, I wasn't ohms...I had only sanded it away before...so now that I have a dremel, I used that and ground the surface down, the resistance is now 0 ohms. The noise was actually gone when I started my car up this morning...not sure why or if its permanent...noise is still gone after fixed batt ground
Guest Posted April 18, 2015 Report Posted April 18, 2015 noise is still gone after fixed batt ground Im not sure if you fixed this or not but it is a grounding issue ground loop
Guest Posted April 18, 2015 Report Posted April 18, 2015 noise is still gone after fixed batt ground Im not sure if you fixed this or not but it is a grounding issue ground loop Not sure if I've permanently fixed it...if it is a ground loop issue, how would you go about trying to fix it?
dbmode2 Posted April 18, 2015 Report Posted April 18, 2015 noise is still gone after fixed batt ground Im not sure if you fixed this or not but it is a grounding issue ground loop Not sure if I've permanently fixed it...if it is a ground loop issue, how would you go about trying to fix it? is the noise still there?
Guest Posted April 18, 2015 Report Posted April 18, 2015 noise is still gone after fixed batt ground Im not sure if you fixed this or not but it is a grounding issue ground loop Not sure if I've permanently fixed it...if it is a ground loop issue, how would you go about trying to fix it? is the noise still there? Noise is gone...for now at least
dbmode2 Posted April 18, 2015 Report Posted April 18, 2015 noise is still gone after fixed batt ground Im not sure if you fixed this or not but it is a grounding issue ground loop Not sure if I've permanently fixed it...if it is a ground loop issue, how would you go about trying to fix it? is the noise still there? Noise is gone...for now at least Good work
Guest Posted April 18, 2015 Report Posted April 18, 2015 noise is still gone after fixed batt ground Im not sure if you fixed this or not but it is a grounding issue ground loop Not sure if I've permanently fixed it...if it is a ground loop issue, how would you go about trying to fix it? is the noise still there? Noise is gone...for now at least Good work Thanks for the help bro!
islandpride684 Posted April 25, 2015 Report Posted April 25, 2015 just go through each step and just verify everything... http://www.termpro.com/asp/pubs.asp?ID=121 Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
