Jordan Thurston Posted May 2, 2015 Report Share Posted May 2, 2015 Just got an alpine mrp-m2000 off eBay said it works fine which it does it powers up works fine at moderate volumes but when I turn the volume up to about 3/4 volume it cuts out. Any idea what's going on do I just have a bad amp ? Link to comment Share on other sites More sharing options...
firebirdude Posted May 2, 2015 Report Share Posted May 2, 2015 Monitor voltage and ensure it's not over heating. What load do you have on it? Sounds like it's kicking into protection of some kind. Link to comment Share on other sites More sharing options...
sirhutson Posted May 2, 2015 Report Share Posted May 2, 2015 what kind of voltage do you have at the amp at high volumes? boss 1200 and a ipod nano. Link to comment Share on other sites More sharing options...
Jordan Thurston Posted May 2, 2015 Author Report Share Posted May 2, 2015 Subs are wired to 2 ohms seeing 2.2 ohms at the amp checked with a multimeter I will have to check the voltage when it's at high volume I'm thinking it has to be something with not getting enough power I had 2 hifonics 1500 watt amps in there before this amp and they worked fine but because this amp is actually 2000 watts it's maybe drawing to much power I have an agm under the good stock 120 amp alternator 1/0 power wire and 2 smaller agms in the back. Link to comment Share on other sites More sharing options...
Jordan Thurston Posted May 2, 2015 Author Report Share Posted May 2, 2015 Would the subwoofer phase have anything to do with it ? It's set at 0 vs 180 Link to comment Share on other sites More sharing options...
Jordan Thurston Posted May 2, 2015 Author Report Share Posted May 2, 2015 I think something is going on with my alternator it started out at 14.6 volts cranked the volume it dropped to 12.3 volts then I turned the radio down it went to 13.9 volts then slowly dropped to 13 and is staying at about 13 volts almost like the alternator isn't charging like it should Link to comment Share on other sites More sharing options...
Jordan Thurston Posted May 2, 2015 Author Report Share Posted May 2, 2015 I got the amp to play pretty loud without cutting out but if I push it a little further it cuts out the voltage will drop to 11.5 so at this point I think I need to get a bigger alternator and a better battery in the back Link to comment Share on other sites More sharing options...
sirhutson Posted May 2, 2015 Report Share Posted May 2, 2015 I got the amp to play pretty loud without cutting out but if I push it a little further it cuts out the voltage will drop to 11.5 so at this point I think I need to get a bigger alternator and a better battery in the back BIG 3. add a batt. boss 1200 and a ipod nano. Link to comment Share on other sites More sharing options...
Jordan Thurston Posted May 2, 2015 Author Report Share Posted May 2, 2015 I will do the big 3 and I will get a nice battery for the back they make a 170 amp alternator for my car it's the one that comes on the police car version of my car it's 140 bucks would it be worth swapping it for my stock 120 amp alternator Link to comment Share on other sites More sharing options...
Jordan Thurston Posted May 2, 2015 Author Report Share Posted May 2, 2015 What would you recommend for a battery ? I was looking at an xs power d3400 Link to comment Share on other sites More sharing options...
