brentpadgett Posted May 10, 2015 Report Posted May 10, 2015 New here so please bare with me! Trying to do the Big 3 upgrade and so far I have replaced the factory ground wire with Sky High 4ga wire with the 4ga lugs, solder method! I also grounded the battery to the chassis since the battery was only had one 8ga ground to the block. With all that said I am still running with stock with from alt to fuse box under hood then looks like fuse box to battery, hope you are still with me on this! My question is do I disconnect wire from alt and fuse box and run wire from alt to battery with a 300amp fuse? Any help would be great and I will add pic to show what I am currently running. Thanks
