Subwoofer spl box help
Hi everyone. Ok so I'm in the process of designing a new spl box for my 15" subwoofer. It is a Targa Viper series and is rated at 2000rms.
The box I have come up with given my space is as follows.
w-38 inches
D-17 inches
H-18.5 inches
that will give me just under 7 cubic feet.
Subwoofer will be facing the back of the car and it will have a 8 inch aero port.
The whole thing to be tuned to 30 hz.
Could anybody give me some pointers if I have the wrong dimensions or anything else that would hinder my spl?
and also any tips welcome
thanks
Just some extra info.
it's for a dodge caliber.
the sub will be running off of 800RMS.
it is a 4 ohm dvc wired to 2ohm.
I am also contemplating on the tune I'm not sure if I'm happy with 30 hz, maybe more mid 30s? As I said I just want some advice so I'm open to all the info you can offer
SPL boxes are tuned far much high than 30hz and are mainly for burping. If what you looking for is a loud daily setup you probably better off tuning in the 35-37hz so you also keep your low end. 7 cubes is also way too big for a 15inch. Has Targa started putting up ts parameters now? That would help with a box design
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
It was ver difficult to find but I have come across these from different sources.
2000 RMS Power
FS - 25.8Hz
SPL (Efficiency, 1W/1M) - 90.4dB Nominal Impedance - 2/4/8 Ohms
Qts - 0.47
Qes - 0.52
Qms - 4.46
Vas - 102.4L
Mounting Depth: 190mm
Mounting Hole Diameter: 355mm
xmax - 16mm
Yah they could be accurate except for the 2000rms part. I have used the Targa Comp 18s and Targa 15" Venoms before. My pc is down so I can't verify but I do know that the 15" targas work well in the 3.5-4 cube box range
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
  • Who's Online   0 Members, 1 Anonymous, 9081 Guests (See full list)
