Jordan Thurston Posted July 3, 2015 Author Report Posted July 3, 2015 Install looks great, like the step by step. Thanks I can't believe the difference in sound with the deadener installed deffinately worth it. I did inside the door panel and the outside part of the door panel took some time but it sounds so much better
Stephen13 Posted July 3, 2015 Report Posted July 3, 2015 I'm guessing a panel popper tool was all that was needed to pull the trim panel then? 2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab "Enjoy yourself. It's later than you think."
Jordan Thurston Posted July 3, 2015 Author Report Posted July 3, 2015 I'm guessing a panel popper tool was all that was needed to pull the trim panel then? I just used a flat head screw driver
Jordan Thurston Posted July 10, 2015 Author Report Posted July 10, 2015 Just ordered some more 1/0 power wire new fuse block and some lug terminals and heat shrink from sky high car audio so I can move my battery to the trunk and start sealing off the trunk and facing the subs towards the inside of the car
Jordan Thurston Posted July 14, 2015 Author Report Posted July 14, 2015 Got some goodies in the mail today but they forgot to ship the ring terminals only got the fuse block power wire and heat shrink so have to wait till I get the terminals to move everything around
Jordan Thurston Posted July 14, 2015 Author Report Posted July 14, 2015 Gunna try and get started in sealing off the subs from the trunk I took some blankets and stuffed them on the sides of the box and on top and that made a difference so I'm really hoping if I seal it off with mdf and expanding foam it will be even better
Jordan Thurston Posted July 14, 2015 Author Report Posted July 14, 2015 Here's what I'm working with right now thinking maybe a 2x4 across the top with some spray foam to seal the top then maybe some mdf on the side and some more spray foam gotta do some experimenting to see what works best
