Well i just checked my email to see if they sent out my lugs and it looks like there sending my whole order again so another 20 feet of 0 gauge and more heat shrink and the lugs so that's really cool of them to do that be ordering more from sky high in the future for sure
Did you figure anything out to deaden the rear bumper?
I ended up putting expanding foam behind which helped a little but still rattled but now that the subs are facing forward the only thing that rattles is the trunk lid which should stop after I seal the subs off from the trunk
I got my lugs today so I ran my new power wire and put my new fuse block in mounted it to my cars fuse box cover
621EC67B-FB4A-41AE-95B2-FD3C15D6FAF1_zps
And here's a pic of my trunk still gotta zip tie some wires up and maybe build some type of box for the battery amp has rubber spacers between it and the box to help with the vibration if there is any. Next project is to start with sealing off the box I've been being lazy and haven't started yet still trying to figure out exactly how I'm gunna do it and make it look decent to
ED63FB30-C42E-4C10-A872-AC8EFBF87CDF_zps
May have an issue with one of the subs it's not moving quite as much as the other one and it's made a weird noise twice now both times on a low note almost like it hit the mechanical limit or something. Coil looks fine nothing out of the ordinary not sure what's going on but on a side note I got my new 10 gauge speaker wire from knu for the subs and my terminals
C54DB2EA-6F25-4483-B937-F587C815D1BD_zps
Picking up the fiberglass mat resin and some body filler after work gunna try and seal off my box better with some beauty panels would I be able to make them out of cardboard then put resin on the cardboard let it harden then fiberglass and body filler after that ?
Ok so I finally started making my fiberglass trim peices to cover up the expanding foam first I trimmed the foam down as best as I could
6DD7DFB9-714D-4E71-96E8-386A23C5AB6D_zps
C47B23D8-C773-4F29-8DC1-D11477E4CFC8_zps
Then I taped it all off and started laying down the fiberglass kinda turned out looking crappy think I put to much resin and not enough of the glass Mat but it is my first time using fiberglass I think they will look ok after I trim them up and add some bondo to them then I'll sand them down and probably wrap them with vinyl or maybe carpet them to match the interior
A5299FAC-6BC3-4AB6-8C4D-4719A96B4BC0_zps
2CC93A55-4559-46E1-8E21-D433268303BD_zps
Finished with the fiberglass part added some bondo and did some trimming and sanding one side is fitting pretty good gunna do some more sanding and probably wrap them with carpet to match the car or paint to match the box not sure yet but here's some pics of the trim peices the one I haven't sanded yet so it looks pretty rough and I added to much hardener to the bondo so it hardened to fast on me.
07B201E4-CE2B-4D69-B4C8-F05046121B46_zps
95DB6EC8-ACA1-4E71-A836-54CB3347B2C4_zps
B91E49C7-3B17-497E-9680-F8C657AE476F_zps
  • Who's Online   0 Members, 0 Anonymous, 3647 Guests (See full list)
