mike-g Posted November 30, 2015 Report Posted November 30, 2015 I have 2 crossfire bmf1000.d amps.1 of them has no problems that I know of ,the other one comes on but doesn't have sound unless you switch the master\slave switch and then it's abump\pop sound only and only when the switch is moved.nothing seems burnt or wrong inside that I can tell but I don't know much about amps.anyone with knowledge about this please help me ,thank you
Frank H Posted November 30, 2015 Report Posted November 30, 2015 Sounds like its not getting a signal. Check to make sure your RCA's are providing a signal. Try switching rca's from one amp to the other. Scion xBSinger 275Big 3 OFC 1/0Kenwood ddx492Alpine 4ch f600 - Alpine components SoundQubed 4500 - Sundown Audio X12
mike-g Posted November 30, 2015 Author Report Posted November 30, 2015 Rca works for the other amp,and my autotek amp but could be bad on the amp I'm asking the question about
mike-g Posted December 2, 2015 Author Report Posted December 2, 2015 Is it possible the master\slave switch is bad,would that cause it to not have output if its in slave and its hooked up like the master?
