4th Order Design Help
SlamminBeats
Based on your dimensions you have slightly under 3 cubes to work with which should be fine for two 8s, one 10 or maybe even one 12. The sub orientations you have posted look ok though personally I would do the single sub setup exactly like the double setup but with 1 sub.
i will play with the dimensions. Still not sure what to do with port.
IF this doesnt work out i may try an IB with a DD 1515. IT has the specs to be a IB woofer. Just worried my trunk will rattle way more than i'd like it.
I like the 4th idea better than the IB. Having the port through the ski-hole will work best. Plus the 7x9 is enough port area for either route you take.
Vw Polo
Pioneer Deh-6050UB
Sundown Saz-3500d
DD Audio 9500 15''
5.5 cubic feet box with 10 inch port @ 38hz
I live to hear the Bass drop!!!
  • Who's Online   0 Members, 0 Anonymous, 1351 Guests (See full list)
