EddieC Posted December 29, 2015 Report Posted December 29, 2015 Is a Schumacker SE-1020D sufficient to trickle charge this battery? The charger is a deep cycle 6-12v selectable with hold or up to 12 hour charging timer. Will this work on this battery, or is something different needed? I can't find any direct answer from Google, so I figured it best to ask the experts. Over the last year, my voltage has dropped from 14.4 to 14.2 or less until warmup. At which point 14.3 seems to be the highest but doesn't hold like it used to. Any advice or suggestions would be greatly appreciated. Thanks. Current install: Pioneer DEH-X8600BH HU AQ200.2 front stage amp Q1-2200.1 sub amp 2 12" SSA DCON subs in 4cu ported tuned to 32 Hz Image Dynamics CTX65 drivers Image Dynamics XS28 tweeters Kicker DS40 dash speakers KnuConcepts 4 gauge wiring for AQ200.2 1/0 OFC big 3 and rear battery/sub amp runs 220 amp HO alt from Js Ultimate Alts Second Skin Damplifier Pro deadening Optima Yellow Top Group 34 / 78 under hood Die Hard Platinum Group 31 marine in rear Stinger voltmeter
