MusicHead804 Posted January 30, 2016 Report Share Posted January 30, 2016 I have a power acoustik 6000d powering my subs at the moment. my budget has just went up on amps. working with about 850 max, any suggestions? (i'm also looking into an alt, i have a d3400 xspower under the hood right now, with the big 3 done) Link to comment Share on other sites More sharing options...
chad190 Posted January 30, 2016 Report Share Posted January 30, 2016 I had 2 hds312's on a soundqubed 2200 @ 1 ohm. I had an agm under the hood(3400) with an xs d3100 and a kinetik hc2400 in the trunk. voltage always stayed above 13.8. that amp was perfect power for those subs too EDIT: the 2200 is only like 430 shipped so you'd have plenty of wiggle room for a nice singer or mechman alt. 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
MusicHead804 Posted January 30, 2016 Author Report Share Posted January 30, 2016 the problem is, i got d2's, they sent me the wrong subs Link to comment Share on other sites More sharing options...
chad190 Posted January 30, 2016 Report Share Posted January 30, 2016 well, that means you have two choices: wiring at .5 ohms (not recommended and will void warranty) but with a big alt and 1-2 batteries that amp will be fine at .5 daily. or, you could always strap two 1200s for a 2 ohm nominal. little more expensive, but gives you what you need. have you talked to soundqubed about receiving the wrong subs? 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300 Link to comment Share on other sites More sharing options...
MusicHead804 Posted January 30, 2016 Author Report Share Posted January 30, 2016 its to late to take them back i've had them too long and i was to lazy to send them back. i was thinking of taramps but i just be seeing mixed opinions that make me change my mind on them Link to comment Share on other sites More sharing options...
RainStryke Posted January 30, 2016 Report Share Posted January 30, 2016 I would recommend this amplifier over the SoundQubed 2200.2: http://store.soundsolutionsaudio.com/products/ampere-audio-aa-2000-1-2000w-mono-block-amplifier.html If I recall correctly, you have D2 subs and you need something at either 2OHM or .5OHM? If so, I would suggest this: http://www.droppinhzcaraudio.com/sound-magus-vs3500-1-high-performance-class-d-5-ohm-stable-mono-bass-amplifiers/ Then spend the extra money on a strong second battery. Link to comment Share on other sites More sharing options...
