Ok guys so im about to buy the rest of the stuff i need to complete my build. Could any of you guys give me some tips on if i should change anything or if im going to have enough to run full 14v.
Right now i have 2 Soundqubed Hds315s D4,Kicker 6x8 and 6x9,SoundStream pn 500.4d for the side speakers,pioneer x6700bs,Stinger Volt Meter. The rest that i am following up on purchasing is this:
Custom Box Built to 28hz
Sky High Car Audio "Big 3" Upgrade Kit 5ft 1/0 CCA with 300 amp fuse
Sky High Car Audio 1/0 CCA Amp Kit with 300 amp fuse
XS Power D3400 for trunk battery
Sky High Car Audio 14ga CCA Speaker Wire Red and Black 100 Feet - for side speakers
FSD Audio 2600.1 2600W Amplifier for sub
All this is going into a 96 grand marquis will i be able to run at 1ohm and get 2.6k out of the amp and not have to worry about clipping/distortion or am i over doing it?
My opinion don't get CCA get ofc (even if you have to get welding wire to keep cost lower just make sure you get bigger welding wire that audio wire because the audio wire is over sized)
Also I try to stay away from amp kits (and big 3 kits) its usually cheaper to just buy a spool of wire and make it your self)
I don't think CCA is rated for 300 amps but idr
That sub amp seem afully cheap for a true 2600 watt amp but idk
