Got the truck tonight. Premimum 2wd edition and thing lays posi pretty easy im surprised. One things for sure IT NEEDS A DROP BAD
Stock front 35.75 ground to fenderlip
Stock rear 38 7/8 ground to fenderlip. Rear needs help bad.
Suspension/20-26" replica wheels plus more
2016 Cadillac Escalade modding
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
NSince im a magnaflow dealer i decided to order the 3.5 inch cat back for the truck.
TBSSowners.com Store - 2015 UP Magnaflow 6.2 Kit (Powered by CubeCart)
I will be cutting off the 3rd waste of space cat and doing the full 3.5 inch from the y pipe back. I have to see if I can make the y pipe a 3 inch fill unit also since bottom is flattened
Rear lowering kit ordered
TBSSowners.com Store - 2015 UP GM SUV 1-4.5 Rear Adjustable Kit (Powered by CubeCart)
along with the front/rear swaybars from djm
TBSSowners.com Store - 07 Up DJM Swaybar Set (Powered by CubeCart)
and
djm rear hardware kit with bumpstops for free travel mod
TBSSowners.com Store - DJM 07 UP Rear Hardware Kit (Powered by CubeCart)
oh i forgot AFE INTAKE
TBSSowners.com Store - 2015 UP GM SUV AFE Intake (Powered by CubeCart)
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
came home and parts started to show up. Have the suspension almost all here. Will be dropping it off tomorrow at the powder coaters. Going to do it all in semi gloss black. Im trying to make the swaybars/springs/mounts etc all look factory.
if you need afe intakes just holler can save you over summit or jegs. I will be doing a before/after dyno of the intake also
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
Got some of the items back from powdercoaters for suspension
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
will be getting the brackets powercoated to match the bars.
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
got rid of the wood grain today had it all wrapped
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
so worked late today but got few things done.
Truck was at 35.5 front rear comes in at 38 1/4 ground to fenderlip
Did the free tavel mod on pass side bracket cut off which gives 3 more inches of travel finish up drivers side tomm
insulators on these things are big. I just wrap heater hose on top and bottom coils on them but the oem ones give the truck a 13/16 lift
Belltech 5305 coil left vs oem spring right. Yes i had the belltech springs coated to match oem. OCD strikes again
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
Finished cutting the drivers bracket put the belltechs in along with the djm links. Rig rides nice and came down 4.25 inches..... but its not low enough for me Ill post up pics with the rear dropped tomorrow. Im planning to do the swaybars and front drop this weekend. I have a feeling ill be putting in my custom spring in rear and getting rid of the autoride to slam it.
26" tires came in today also.
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
