Swaybar was pointing up way to much and ended up getting the energy suspension endlinks. These are adjustable so also a great mod for the 08 up tbss guys here. Installed and very happy with results. Front end feels much more planted due to the endlinks and swaybar being parallel with ground
stock vs new one
Parallel with ground now
Suspension/20-26" replica wheels plus more
2016 Cadillac Escalade modding
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
Been doing this set up for the guys that want a little more bump without spending $$$. Replace oem filter with green filter or k&n and then do this mod. Very easy and MUCH more air coming in.
Remove stock intake box and you have this small entry for air flow
Then your left with this and you can see how much is blocked off on cover and box.
4 inch cut off wheel cut the cover but do not cut the locking tabs on it
Left with this. Ill clean it up with a dremmel
cut the box plastic and then clip the cover back on
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
Time to get the suspension ready for the BIG WHIPPLE 2.9 and got the helper bags in rear going. My custom 6 inch springs which are the 2.5 for the tbss :)
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
I ended up taking my escalade in to get pre WHIPPLE Supercharger numbers.
2016 ESCALADE
STOCK TUNE
5TH GEAR PULL
AFE INTAKE
MAGNAFLOW 3.5 CAT BACK
376 rwhp/411 rwtq
Did 3 other pulls and they were all 1 to 2 hp away from above results so consistant baseline
I'm very happy with the results. Stock 15 escalade dynoed 331/359 2 weeks ago which customer also bought a whipple kit from me so he wanted before/after numbers
I took time off work on the 8th so I'll be installing the blower. I'M AMPED. If truck makes 500/500 I'll be happy
2016 C7 z06 modding
2013 Ctsv 850hp
1996 Impala SS
  • Who's Online   1 Member, 0 Anonymous, 1144 Guests (See full list)
