polish1327 Posted November 30, 2006 Report Posted November 30, 2006 Can somebody show me a diagram of wiring to batteries together. One battery would be in the back and the other up front in the engine comparment? Quote Nismofreak School account.
FieroGrande Posted November 30, 2006 Report Posted November 30, 2006 You can always look at knukoncepts wire. its Cheap! And yes you can wire the cap that way. Caps are overrated tho. its just another current draw on your electrical system! Quote
FieroGrande Posted November 30, 2006 Report Posted November 30, 2006 Not unless you hook something up backwards. Quote
FieroGrande Posted November 30, 2006 Report Posted November 30, 2006 Make sure that the positive is hooked up to the positive on the cap. Thats all. It should be simple to do. :^ Quote
Guest MegaloManiac Posted November 30, 2006 Report Posted November 30, 2006 I gettin probably a 10 cap for my audio system so one positive in and one positive side the other way. u r wastin ur money... to answer ur question Yes Quote
Guest MegaloManiac Posted November 30, 2006 Report Posted November 30, 2006 I've got 60 amp on my alterntor plus one optima yellow top battery so u expect a cap to create its own power? Quote
Guest MegaloManiac Posted December 1, 2006 Report Posted December 1, 2006 hell no. Yes want the power to be pushed out faster plus should i upgrade my alternature upgrade that alty... a good alty can keep up with the power so there is no need for a cap. alty brands: Iraggi, Excessive Amperage, Ohio Generators, HO Alt...etc put the biggest fuse for that wire. a fuse on the wire is to protect the wire, your amps have their own fuses Quote
Guest MegaloManiac Posted December 1, 2006 Report Posted December 1, 2006 so no need for a cap if i will have a 190amp alternatue plus one more battery/ you will never need a cap in life...as far as caraudio goes Quote
Guest MegaloManiac Posted December 1, 2006 Report Posted December 1, 2006 really so what is a cap used for because i have xeon headlights, 4 neon lights inside, underbody kit caps are electrical "band-aids", with a High Output Alternator you will never need a cap Quote
